Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Install NodeActa Server on Linux
#1
Prepare Linux environment with required dependencies:
      sudo apt update
      sudo apt install -y wget unzip libtommath-dev libicu-dev systemd libaio1
Depending on the platform, libaio1 may not be available. In such cases, libaio1t64 should be available as an alternative.
If you install NodeActa server using the default settings, the setup will download and install the Firebird 5.0 database server.
If you prefer to use Oracle or MySQL as your primary database, you will need to choose the database type during the setup process.
Important: The setup will not automatically install Oracle or MySQL servers. However, for Oracle, it will download and install the latest Oracle Instant Client.
If you are updating NodeActa binaries over existing installation, please call:
      systemctl stop nodeacta.service
Install NodeActa server:
      sudo dpkg -i nodeacta.server.x64.deb
Reply
Forum Jump:
Users browsing this thread: 2 Guest(s)
