Signers
To digitaly sign a document you must define a signer first.
In the picture below we have an example how to define a signer for .pdf file format. Signing is implemented using node-signpdf library from www.npmjs.com repository (see how to install module from NPM in Module Manager).
signers
After defining a signer for a certain file type, you will get Sign command in the context menu of FilesView control (see image below).
signers.sign
Signer will use a certificate assigned to currently logged user. In the case when logged user has more than one certificate, Select Certificate window will be shown. How to manage user certificates you can find here.
To sign a .pdf file in your code, you can directly call matching signer. For example:
const { pdf } = await import('nv:SystemManagement.Signers.pdf');
var cert = <select one certificate from env.certificates>;
await pdf.sign(inFilePath, outSignedFilePath, cert);
You can access all certificates available to logged user via env.certificates.
